[quotePost id="115873"]I've figured out the same problem. The native editor for text elements and content within the YoothemePro Builder (Joomla 5 / PHP 8.2) doesnt' load anymore with JCE 2.9.60. Unfortunatley there isn't any JavaScript error in the console. The Yootheme Pro has got an own, simple editor.[/quotePost]
This is a different issue to the one originally posted, which is to do with the editor-xtd buttons below the editor, not the editor itself.
The Yootheme issue appears to have something to do with the way Yootheme uses a custom method to intialize the editors, which now does not work with the recent changes in JCE Pro 2.9.60. I am trying to find the cause of this, so I can either fix it or suggest a fix to Yootheme.
