#115848 Filesystem directory filter not working
Latest post by da.andres on Thursday, 18 January 2024 15:15 GMT
da.andres
I'm using the latest JCE Pro Editor extension.
I have one profile for all users (managers, administrator and even the super user).
I want to use the JCE Filesystem to restrict the users to upload to specific folders and none others.
This is our filesystem:
images/news --> allowed
images/static_a --> allowed
images/static_b --> allowed
images/restricted_static_a --> not allowed
images/restricted_static_B --> not allowed
images/ --> files not allowed, only subfolders defined allowed
As I have understood the directory filter, the folders with "not allowed" should be hidden and not allowed to read and write. However, the folders are visible and writable.
How can I achieve the use case above?
Thank you for help
Are you using JCE Pro 2.9.60? - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
da.andres
I have upgraded to 2.9.59 recently and was not aware of .60. But with .60 the specified folders are hidden. Thanks.
However, How can I restrict in the root folder (file directory path) the creation of files and of subfolders? I want my users to use the predefined folders and upload or create subfolders there and not at the first level.
Thanks.
You can't restrict actions (create folder, upload etc.) by folder path, only globally for a specific plugin - Image Manager, File Manager etc.
da.andres
ok thanks.
