Your session has expired. Please log in again.
The security token did not match. The request was cancelled to prevent any security breach. Please try again.
#112287 Mediabox pop up for pictures
Latest post by IDD-NET.DE on Thursday, 17 November 2022 19:36 GMT
IDD-NET.DE
We found that the pop up and subsequent resize for a photo on a cell phone only works on iphones, but not on androids.
So when you click on the magnifying glass, the photos opens as a pop up. On android you can not do more. On iphones, on the other hand, it is possible to scale the image larger with your fingers - which is also desired and necessary.
How can you fix this?
thx....O.D.
IDD-NET.DE
Hi, please, I need a solution, customer is not amused, that it doesn't works.
thx...O.D.
Unfortunately I don't have physical android device to test this on.
If you go to this lightbox example on an android device, and click the Image button, can you scale the image? - https://getuikit.com/docs/lightbox#content-sources
IDD-NET.DE
Good evening,
yes, I have no Android either :-)
But I tried it now and on both iphone and android scaling only works as a whole, but not after clicking the image button.
Here is the website where it does not work:
www.st-vinzenz-noerdlingen.de
https://st-vinzenz-noerdlingen.de/index.php/unser-verein/von-ambulant-bis-stationaer/tagespflege
Here is the photo below as an example. In android nothing scales here at all unfortunately.
Customer want it to have like on a iphone.
Thanks for help!
cu...O.D.
