#110863 Using Column Layout Feature but custom css is removed?
Latest post by Ryan on Tuesday, 26 April 2022 10:03 BST
bri-2.0
I am using the column feature layout in an article, it works really well - but when I add additional css for styling as soon as I 'save and close' the article new css is removed.
If I do not toggle back to the preview view and remain in code view I can save the document and view my styles on the front end.
I have added div and css to the allow in the editor profile, checked the Joomla prohibited settings and just can't see the issue.
The attached shows the two classes I add to each column. They are the ones removed on save and close.
Thanks for your help
Britt
Please try JCE Pro 2.9.23 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
bri-2.0
I've installed and it now does not strip away the custom css, but it does still strip away additional column control css. See my examples to get an idea on what it changes.
e.g. if I set col-lg-4 col-md-4 on save the col-sm is reinstated.
Appreciate your help 😃
Thanks Britt
bri-2.0
Please try JCE Pro 2.9.23 Beta 7 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
bri-2.0
Its improved, but still stripping and replacing css. See the screens
The second column, removes the col-lg-8, retains if I do not go back to edit view mode. But as soon as I save and close the file and reopen, it has stripped away the new css on that row only. Oddly it retained the first col-lg-4?
It also adds back the unrequired col-sm which I don't use because I have to be more granular across devices.
Thanks again for helping with this, it's a great feature.
Britt
bri-2.0
And images I am getting an error on uploading small files under 300KB each, no sot sure why. I can email them if this is not able to be resolved. I have tried two different browsers and the error I get is
'The file 2022-04-22_09-21-50.png, which you are attempting to upload is exceeded the maximum file size.'
bri-2.0
you have max upload set to 0.25MB...so here are two very optimised images. I can't do much smaller than this.
When you create Columns, you select the Stack Width and Layout for the columns, which results in a set of classes being applied to the divs, in this case the col-sm and col-sm-8 values.
Removing these classes, or adding others, will change the original layout and stack width, and adding some classes that are used by Columns to create these layouts, such as the col-lg-8 value, will then change how the columns are processed.
If you want to add your own layout values, then I would suggest removing the data-wf-columns="1" attribute in the parent container, so that the layout is no longer processed as Columns, and you can add your own classes as required.
