Here the problem is Joomla not JCE - Any hint will be appreciated
I’m using JCE for a long time and I’m trying to repair the horrible Joomla frontend edition system to something more modern.
I like that when a user click the edition icon in the frontend it will be redirected to a modal box and not in the Joomla Component Aera, as it does now.
I find a part of the solution here:
How to show the module editing page in a popup modal?
https://joomla.stackexchange.com/questions/22545/how-to-make-frontend-module-editing-as-modal-in-a-custom-template
1• Make an override of layouts/joomla/edit/frontend_modules.php in
templates/…Your_Template…/html/layouts/joomla/edit/frontediting_modules.php
2• Extend line 34 with &tmpl=component&context=modalselector like this:
From original:
$editUrl = JUri::base() . 'index.php?option=com_config&controller=config.display.modules&id=' . (int) $mod->id . '&Itemid=' . $itemid . $redirectUri;
$target = '_self';
to
$editUrl = JUri::base() . 'index.php?option=com_config&controller=config.display.modules&id=' . (int) $mod->id . '&Itemid=' . $itemid . $redirectUri .'&tmpl=component&context=modalselector';
Make sure the main component is used/hidden on that page and you will be returned correctly....
I try this and my edit button open in another window, unformatted and the editor and content is missing (JCE).
— Only the unformatted Joomla edit functions interface appear and JCE and the content is not present.
I guess the —> “&context=modalselector';” is wrong??????????
I use Joomdev Astroid with Bootstrap 4 and use JCE Pro — I guess i can use one of these modals but I don’t know enough coding to implement and not sur how to keep the formatting of the editor window (Joomla and JCE)
Continue testing.....
