#106559 Captions class causing problems
Latest post by Dolcevia on Monday, 01 February 2021 18:43 GMT
Friday, 29 January 2021 12:35 GMT
Friday, 29 January 2021 13:34 GMT
Friday, 29 January 2021 14:02 GMT
Friday, 29 January 2021 14:47 GMT
However today when I turned it back on (it was the new version which I hadnt used before) I saw these small problems.
This may be the cause then, as it looks like things are being processed 3 times, which is why you see 3 captions.
Have you played around with the JCH settings? I can take a look if you want -> https://www.joomlacontenteditor.net/contact/site-login
Friday, 29 January 2021 14:52 GMT
I have indeed tried to turn things of and on and tried excluding several files. I am a bit baffled to be honest.
Please have a look, it certainly will be easier for you I am sure.
Thanks!
Liz
Friday, 29 January 2021 15:24 GMT
Friday, 29 January 2021 15:38 GMT
Friday, 29 January 2021 15:39 GMT
I did didnt I? But I just saw you are in, so I suppose you found it. 🙂
No, I've not received anything. Please use this form only to send the login -> https://www.joomlacontenteditor.net/contact/site-login
Friday, 29 January 2021 16:06 GMT
Friday, 29 January 2021 16:37 GMT
Friday, 29 January 2021 16:49 GMT
Sunday, 31 January 2021 10:29 GMT
Monday, 01 February 2021 09:16 GMT
Monday, 01 February 2021 10:35 GMT
However it still doesn't work...:(
Monday, 01 February 2021 12:59 GMT
Monday, 01 February 2021 16:54 GMT
Hi Ryan, I used a css file this time, called it editor.css and put it here : https://www.dolcevia.com/nl/templates/g5_hydrogen/editor.css
You still had an scss file assigned in Editor Profiles -> Plugin Parameters -> Style Select. I have removed this value and the Styles list is displaying in the editor again.
Please wait
Your post is being submitted…
