#106278 Troubles using "Columns" feature
Latest post by nalta on Friday, 08 January 2021 08:00 GMT
nalta
Hello !
I'm trying to use the "Columns" feature and i can't manage to add content above or under a row...
The only way to get a line break is to go through HTML and add a <p> for example
Is there another way ?
Thank you
Regards
Use CTRL + ALT + Enter to create a new paragraph below the columns, or CTRL + ALT + UP to create one before.
nalta
Thank you !!
