#115708 editorIframe Problem sind 2.9.56
Latest post by kreativ quadrat on Tuesday, 02 January 2024 18:01 GMT
kreativ quadrat
we save th form via ajax and have following script to get text from JCE
// Access the JCE editor iframe
var editorIframe = document.getElementById('description_de_DE_ifr');
if (editorIframe) {
var editorContent = editorIframe.contentWindow.document.body.innerHTML;
var descriptionInput = document.getElementById('description_de-DE');
descriptionInput.value = editorContent;
since 2.9.56 this do not work
what do you change since 2.9.56?
2.9.55 works
thx
// Access the JCE editor iframe var editorIframe = document.getElementById('description_de_DE_ifr'); if (editorIframe) { var editorContent = editorIframe.contentWindow.document.body.innerHTML; var descriptionInput = document.getElementById('description_de-DE'); descriptionInput.value = editorContent; }
You sould not use a method like this to extract the editor contents, as this will get the "raw" editor contents which may contain system elements. To get the editor content use:
var ed =  Joomla.editors.instances['description_de_DE'];
if (ed) {
    var editorContent = ed.getValue();
or
var ed = tinymce.get('description_de_DE');
if (ed) {
    var editorContent = ed.getContent();
kreativ quadrat
works....thank you
