#115676 Problem Resizing and then Cropping images
Latest post by albatrozdigital on Wednesday, 10 January 2024 11:37 GMT
albatrozdigital
Hi!
I'm having a problem uploading images and then resizing and cropping.
I have defined that my website will only have images with 1280x720.
So i need to upload images and the resize and crop to that size.
Example: i have an image with 2339x3307
After the upload, I will edit the image and then resize it to 1280 x (what it gives), in this case JCE changes the image to 1280x1810
Then, i will crop to have an image of 1280x720.
But when i edit the fields to correct the height to 720, it changes the width to 1279 and the height to 721, this is wrong.
Why can't i have the full width of the image that is 1280 and then cut some height to have the 720?
What is wrong? Can you fix this?
Uncheck the Propotional box to enter in your own non-proportional values.
You can do this when the image is uploaded, it does not need to be done in the Image Editor after uploading.
In the Upload dialog, browse for and select the images to upload.
Check the Resize option, then uncheck the Proportional box. Type in your dimensions. Check the Crop to Fit box.
https://cdn.joomlacontenteditor.net/tmp/115676-problem-resizing-and-then-cropping-images.jpg
albatrozdigital
But i need to resize proportionally, becuase i want the image to have my width, and then go from there.
I the case of the image in too wide, then i need to resize by the height proportionally.
I never know what images the client send me to put it the articles.
If i do this on the upload the resize and cut is made automatically, and i can't choose what part of the image i want. Sometimes the part in the middle, sometimes the part more on top. I have to choose myself.
If i do as you say, it will choose the middle of the image, that's not what i want, maybe o need a part of the top.
If the image has more width than height, then it will cut the sides.
Can you understand this?
So the solution is to upload the image completely. And then edit and resize to my need (width or height) and then crop to choose the part i want.
I you can just fix the crop thing tho let me choose it would do. The crop is making some calculations that are not normal.
I am looking into this but I am not always able to reproduce a similar issue with the dimensions. It appears to be caused by specific image dimensions, as some images crop as expected while others create dimensions that are 1px more or less than the expected size.
Please try JCE Pro 2.9.59 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
Clear your browser cache after install.
albatrozdigital
Hi!
It's the same.
I will send the image i'm using so you can try.
first resize to width 1280
and then crop to height 720 and choose the top of the image.
you will see that the values change to 1278 and 719
Please try JCE Pro 2.9.59 Beta 2 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
albatrozdigital
Hi!
Same behavior, it changes to 1278x719.
This is working in my tests with your image. Please clear your browser cache.
albatrozdigital
Hi!
I did that.
vídeo
I think I have managed to fix this now. Please try JCE Pro 2.9.59 Beta 3 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
albatrozdigital
Great!!!
It's fixed.
