#106725 SVG-images are not shown on site
Latest post by ucr on Wednesday, 10 February 2021 14:15 GMT
ucr
Hi!
Have changed settings so svg-images is a permitted file extensions in Image Manager Extended, File Manager and Joomla Media.
It works fine to upload a svg-image with Image Manager Extended and select the image and add it to a Joomla article.
But the image is not visible in the article in editing mode or published frontend.
What am I missing?
Regards
Matt
Joomla 3.9.24
JCE Pro 2.9.2 with SVG plugin installed and published
PHP 7.1.6
Please post a link to an example.
Does this happen with all svg images, or just this one?
ucr
It happens with all svg-images, added as images.
But if you scroll down the page you see the purple check marks, they are svg-images, but svg-code added in the editor.
Matt
I am able to embed svg images using the <img> tag, but I am getting the same issue with your svg image. The svg examples here - https://commons.wikimedia.org/wiki/SVG_examples - work for me too, so perhaps there is a problem with your svg images?
I don't know enough about svg to know where the problem might be unfortunately.
ucr
Thanks Ryan for your support!
But I´m still struggling with the same problem, despite that I have tested with a couple of your suggested svg-files.
Can it be a db problem, encoding? "utf8_unicode_ci" should work...
This is not a critical problem, but it had been very nice for my colleagues to have the opportunity to easy change colors for icons.
Your file - the flask svg - does not work when I test it, but the Wikimedia examples, and other svg files I have, do work.
The <img> tag should be able to display the svg from the url, as you would expect, and JCE inserts the tag as required - https://css-tricks.com/using-svg/#using-svg-as-an-img
ucr
Thanks for your support Ryan!
Will not spend more of your and mine time at the moment.
Might have a look at it after the update of our hosting.
Regards
Matt
