- Media fields problem
We have detect problem with Joomla media fields and JCE integrations.
Example:
This fire JCE File Manager with standard custom field but not working with new repeatable field (open default Joomla! media manager not JCE).
Example:
<field
name="image"
type="media"
label="COM_CONTENT_FIELD_INTRO_LABEL"
description="COM_CONTENT_FIELD_INTRO_DESC"
Please try JCE Pro 2.6.34 RC1 - https://www.joomlacontenteditor.net/downloads/editor/pro/development/item/jce-pro-dev
#97613
I just installed JCE Pro 2.6.34 RC1 but still the JCE File browser is not available in the repeatable media fields. See img.
ps. just want to select a single zip file here with each row.
btw. this is a repeatable field created with custom fields under Content
Regards,
Gosling
Regards,
Gosling
#100761
A friend told me please go to plugins/fields/repeatable/params/repeatable.xml
and replace file:
<?xml version="1.0" encoding="utf-8"?>
<form>
<fields name="fieldparams">
<fieldset name="fieldparams">
<field
name="fields"
type="subform"
label="PLG_FIELDS_REPEATABLE_PARAMS_FIELDS_LABEL"
description="PLG_FIELDS_REPEATABLE_PARAMS_FIELDS_DESC"
multiple="true">
<form>
<fields>
<fieldset>
<field
name="fieldname"
type="text"
label="PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_NAME_LABEL"
description="PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_NAME_DESC"
required="true"
<field
name="fieldtype"
type="list"
label="PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_LABEL"
description="PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_DESC"
<option value="editor">PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_EDITOR</option>
<option value="mediajce">PLG_FIELDS_MEDIAJCE_LABEL</option>
<option value="media">PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_MEDIA</option>
<option value="number">PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_NUMBER</option>
<option value="text">PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_TEXT</option>
<option value="textarea">PLG_FIELDS_REPEATABLE_PARAMS_FIELDNAME_TYPE_TEXTAREA</option>
</field>
<field
name="fieldfilter"
type="list"
label="PLG_FIELDS_TEXT_PARAMS_FILTER_LABEL"
description="PLG_FIELDS_TEXT_PARAMS_FILTER_DESC"
class="btn-group"
validate="options"
showon="fieldtype!:media,number"
<option value="0">JNO</option>
<option
showon="fieldtype:editor,text,textarea"
value="raw">JLIB_FILTER_PARAMS_RAW</option>
<option
value="safehtml">JLIB_FILTER_PARAMS_SAFEHTML</option>
<option
value="JComponentHelper::filterText">JLIB_FILTER_PARAMS_TEXT</option>
<option
showon="fieldtype:text,textarea"
value="alnum">JLIB_FILTER_PARAMS_ALNUM</option>
<option
value="integer">JLIB_FILTER_PARAMS_INTEGER</option>
<option
value="float">JLIB_FILTER_PARAMS_FLOAT</option>
<option
value="tel">JLIB_FILTER_PARAMS_TEL</option>
</field>
</fieldset>
</fields>
</form>
</field>
</fieldset>
</fields>
</form>
Hi there,
We're also very interested in this functionality in order to allow PDF uploads with repeatable fields. Therefore, we've added "PDF" on line 54 of /components/com_jce/editor/tiny_mce/plugins/browser/browser.php
secondly, we've changed the XML file as suggested by Karolrzepka. This works perfectly well beside the fact that those changes might be necessary after any update.
Does anybody have an idea how to make this "update proof"? Any help is highly appreciated.
Best regards
Fabian
Best regards
Fabian
Referring to my previous post above, do you have an idea how we can make an update-proof override of browser.php where we've added "PDF" on line 54?
The second topic regarding the JCE media manager in repeatable fields seems to be solved with JCE Pro 2.9.3 Beta 5. Thank you for that!!
Best regards
Fabian
Best regards
Fabian
No, but I am looking into some alternatives for this, perhaps having the media field as a "Component" option in Editor Profiles, so that you can have a profile specifically for the Media Field File Browser.
Hi everybody
Any news about «update-proof» of the pdf-tweek in browser.php or th the «component option» approach?
While I do understand there might be issues with a higher priority, I can't imagine this setting would be a huge trick, is it?
Or did I miss this in a release note?
thanks a lot
Seppy
thanks a lot
Seppy
@Seppy:
Our workaround for the moment is a simple cron-job. I store the modified browser.php file somewhere on the server (in the example below inside the html folder of the template) and send it back to the original place every minute.
cp
/... your path... /public_html/templates/... your template .... /html/cronjob_components_com_jce_editor_tiny_mce_plugins_browser/browser.php
/.. your path... /public_html/components/com_jce/editor/tiny_mce/plugins/browser/browser.ph
