- How to set quality for uploaded or resized images?
I am using Image Manager Extended but I have some issues with the upload and resize features.
The problem is that the resized images are still quite big in terms of Kb. For example if I resize an image externally with 60% quality at 72dpi, this is usually less than half of the same image resized in JCE.
It also happens that I resize an image and the result is still bigger (in term of Kb) than the original image.
I do see an option to set the quality for the optional thumbnails, but not for the resized image, is this something you are planning to add in the near future?
Thank you
Thank you
