In this article you see a table (picture)
I want to link it to Mediabox Popup but that does not work..even picture disappears !
Right now there is a regular popup which works.
How come that Mediabox popup does not work?
I use JCE Editor Pro 2.6.20
Thanks for your help.
#95585
OK, I use same article >
The picture with mediabox popup should be seen above this text: Klik op overzicht voor vergroting. after the first paragraph.
Thanks for your help!
#95586
I now see that mediabox popup works well in full article, but not yet in same frontpage article
Meanwhile I discovered this is caused with Yootheme Widgetkit "Blog Dynamic" which I use on frontpage.
Any idea how to solve?
