#92132
I have exactely the same problem. Yesterday I updated the JCE and now the popup is no longer working.
Did you find the problem?
Regards Heike
Regards Heike
Updating JCE should not affect JCE MediaBox or existing JCE Mediabox popups. Please post a link to an example.
#92217
This is the link
http://www.baiblues.de/index.php/schlagzeilen/596-19-03-2017-max-bairan-zu-besuch
Best regards Heike
Best regards Heike
Please upgrade JCE MediaBox to the latest version - https://www.joomlacontenteditor.net/downloads/mediabox/category/joomla-3
#105429
I have the same problem...The popup doesn't work...The image open in a new tab.
Could you please help me?
Joana
Joana
topinformatica Please post a link to an example popup.
#105431
https://www.topinformatica.pt/novidades.php?categoria=all&programa=all&versao=10
See Capturar.PNG to click on correct image.
topinformatica JCE MediaBox does not appear to be installed or enabled on your site. I don't see the MediaBox scripts being loaded in the site front-end.
Yes, JCE MediaBox is required to show the popups - https://www.joomlacontenteditor.net/downloads/mediabox/development
#105436
Sorry, but I don't understand. I need to copy de javascript and css to my webpage. Is that?
No, you need to download and install the JCE MediaBox plugin - https://www.joomlacontenteditor.net/downloads/mediabox/development
After installation, it must be enabled, see - https://www.joomlacontenteditor.net/support/installation/mediabox
Is this a Joomla site? None of the links - eg: https://www.topinformatica.pt/novidades.php?categoria=all&programa=all&versao=10 - look like Joomla urls.
#105447
No, backoffice is joomla...The site is php and read information the joomla only
#105578
its the same on my site http://www.praxisklinik-brahmsallee.de - the pop-up dosn´t work
i have install the lastet JCE Pro 2.8.19 Beta 6 and the JCE MediaBox 2.1.2 RC 3, but in the backend i have no button.
The pictures on the site can not open in a popup, only in a nwe site
This is the standard image manager not the image manger extended.
You have to add the image manger extended button to your editor layout
https://www.joomlacontenteditor.net/support/faq/editor/pro-buttons-missing-after-upgrade
