- Pop up window settings settings get lost after save
Hi, I'm having some problems with the JCE popup window in the backend. I'm using Joomla 3.7, PHP 7 and JCE Pro 2.6.12.
I've added a menu link in an article and set it to open in a new popup window. I customised the settings - size of window etc. Everything works fine in the front end but if I go to edit the link in the backend, all the settings for the popup have gone, they are not there to edit.
I looked at the code that was being generated for the popup and noticed that the onclick Javascript is repeated twice, I don't know if that is correct. But when I view the code source my browser crashes as soon as I try to click anything else. I'm using Firefox v. 53.0.2 on Mac OS Sierra.
Thank you.
Thank you.
Please try JCE Pro 2.6.14 RC1 - https://www.joomlacontenteditor.net/downloads/editor/item/jce-pro-2614-dev
OK I just tested this process on a slightly older site which is using Joomla 3.6.5 and running on PHP 5.5. JCE is 2.6.8.
Here everything works fine, the settings are available to edit when I click edit link, and I also checked the code source - the onclick javascript code is in only once. Attached screenshot of double code.
I used the same browser.
Also this is a new site not an upgraded site, so the installation is new and pretty basic so far.
