#106706 Making a lengthy article structured (easy to edit)
Latest post by Ryan on Tuesday, 09 February 2021 16:35 GMT
redelevencreative
Hi there
Quick question…have a site I am building and one of the pages contains maybe 10 paragraphs and 15 images.
Images are spread out amongst the text but not uniformed.
Usually I would try and use intro images and chop the page into multiple articles…but that isn't going to work.
How would you suggest I deal with a lengthy page with multi images using only the JCE editor etc? (On a Bootstrap theme)
Any advice welcome.
Cheers
Gav
I can't think of any specific tips to make this any easier, but you might find toggling the Block Elements display makes it easier to and see and navigate between paragraphs and other block elements:
https://cdn.joomlacontenteditor.net/tmp/106706-making-a-lengthy-article-structured-easy-to-edit.gif
