- Breaking out of div using ctrl + end keys
Hello, just a quick one. If you have a table inside a <div> and hit ctrl + end to get to the end, you are still inside the div: you cannot break out of it without going to the code.
This has happened specifically when a table is inside a Bootstrap <div class="table-responsive">.
Container Element & Enter Key settings are Paragraph : Paragraph.
Use ALT + Enter to create a new paragraph outside of the div. See "Exit Nested Paragraph" - https://www.joomlacontenteditor.net/support/documentation/editor/keyboard-shortcuts
