#103383
When editing images on web pages using the JCE editor I use tables to put the images into so they are all in order the table are visible in the editor so one can see what you are editing with an option to make the table properties invisible on the actual webpage
Dave
Dave
The table is made visible in the editor using guidelines, which are only visible in the editor. When the article is viewed in the front-end, these guidelines do not display.
Are you wanting the tables to be visible in the front-end?
#103396
Ryan, I have done a few adjustments myself and everything seems to be working with the JCE editor
Hopefully
Dave
Hopefully
Dave
