Hi Ryan ...
i got a problem with jcepopup box ... it work´s on all my sites and i cant figure this one out ...
https://arch-preis.rrwebdesign.at/test
it seems to be working, if i look at how the mouse reacts ... the popup seems to be opening, but the content i want to open does not show ... i tried it on other of my sites and everywhere it works fine ... just on this one not ...
I put some Information directy in that link i posted above ... (ups ... in german ... i better write it in here again in english)
- newest Version Joomla 3.9.15 ..
- newest JCE ... pkg_jce_pro_286-rc3.zip is installed ... with Plugin Mediabox ...
- Template Flex ... https://flex.aplikko.com/
- SP Page-Builder PRO ...
If you got time and you need an Admin user" that´s no problem either ... let me know ... thx in advance ...
Cheers Richi
References
Pending Moderation
Please try JCE MediaBox 2.0.14 Beta - https://www.joomlacontenteditor.net/downloads/mediabox/development
Pending Moderation
I'd like to add my 2-cents.
First, you suggested using the new beta. I'll try that, but I want to post what "I" found just today.
Very, very odd behavior. I've been posting several videos in my project (updating an entire site for a client) and everything has been going smoothly...until today.
I posted videos in several pages without any problem. They launch in the jcepopup mediabox as intended perfectly.
Until today when I was posting another video.
Today, the popup works - in general - but does "not" open in the proper jcepopup. It works perfectly for the videos that were posted "prior" to today. But anything posted today is knackered.
There is no method to close the popup. I have to use the "back" button to get out of the video, and the video is not sized properly in the popup.
I haven't touched "anything" having to do with JCE in the site since before successfully adding videos. I was even successful at creating a link with a popup video, then edited the link to make it appear as a button (part of the code that works with Themler to create a button with text).
I got frustrated and simply copied the 100% working link - with the button code (from where it "still" is working perfectly) to another page (this is in Joomla), and the page to where I pasted the link is as described above - not working as intended; no method to close the video; too large overall. Even the icon (magnifying glass) does not appear.
I can give you the links to the pages (in my development site) so you can see the results. I've looked at the code, stripped everything and started over from simple text in the article, but NOTHING is working to fix the problem. It's as if something has changed since yesterday when I stopped working on the site - but nobody but me has access.
If I had installed something that may cause interference with other plugins or something, I could understand that it's the plugin. However, videos posted prior to today work perfectly. Anything I've tried today does not work.
I can look at the code in the article and see nothing changed. I can look at the code in "Inspector" and see one thing changed. When you look at the link in the classes, jcepopup is changed to wfpopup. I don't know the internal functions of jcemedia, but I "do" know that all the properly functioning videos have the wfpopup class instead of the jcepopup class.
All those that do not work are using the jcepopup class when inspecting from the front-end.
Please let me know what you find. Hopefully, that wfpopup class tag is a red flag for you to know what's going on.
Thanks.
Thomas
PS - I tried the beta zip and that did nothing - at least nothing I could see. It would seem wfpopup is "work-flow-popup"? Since the class no longer switches to wfpopup after the article is saved, as did the working videos, that is leading to the problem. Yes?
PPS - NEVERMIND! I forgot that I needed to set "every" in page where I want to use the popup in mediabox...sorry. I even installed JCE Pro to see if that made a difference. Thanks.
Thanks.
Thomas
Pending Moderation
I assume you are refrring to the Assign to Menu option in the MediaBox parameters? If you require MediaBox to load everywhere on the site (the default), then just remove all the selected options.
Pending Moderation
Hi Ryan ...
sorry, i was away without internet for a few days …
i just tested the "JCE MediaBox 2.0.14 Beta" and it works o.k. now … popup box working again … Thx.
Thx for your quick reply and for your awesome work in general ...
it´s gotta be said, i really appreciate your JCE editor ;-) ...
cheers ...
cheers ...
Pending Moderation
It seems that this thread is a few months old, but since it is specific to my issue I thought I'd see if it's alright to add to this thread. And, by the way, I'm using the JCE MediaBox 2.0.14 Beta 5.
I'm working here - https://localhire.us/ - to get a popup working. I'm able to get it working perfectly in all areas of the site except where I really need to have it working.
JReviews is the Component I'm using for the "Directory".
If you go here - Local Hire - which is where users create a listing, select "Local Projects" as the Category, scroll to the bottom where you'll find a link to the TOS.
I've made sure that none of the menu items are selected in the JCE settings (in order that the popups will appear anywhere), and, you can see a link for TOS in the footer of the template which is working fine.
For whatever reason, JReviews component is not allowing JCE to work. But you can inspect the element and see that the link has all of the correct JCE parameters.
The link only takes you to the actual page via a new window.
Is this something "I" have not set properly? Or is this something I need to discuss with JReviews?
Thank you for all you create and your time.
Tom
Tom
References
Pending Moderation
Because the data is added dynamically after the page has loaded, it is not processed by JCE MediaBox, so the link is not converted into a popup link.
You will need to create a link that directly triggers a popup, eg:
<a href="#" onclick="jcepopup.open('https://localhire.us/terms-of-service', 'Terms of Service');return false;">Terms of Service</a>
Please install JCE MediaBox 2.1.2 Beta 3 - https://www.joomlacontenteditor.net/downloads/mediabox/development
Pending Moderation
Hi.
Yep. That worked beautifully...after I installed the Beta3 update. I tried before updating and the window just stalled trying to load.
After the update it works great.
Thank you very much.
Tom
I'm sorry! I spoke too soon.
I tested in the directory and it works great.
But in the template footer link (the original link and not the updated one you provided (above), the window opens but with an "addition" window inside - like "picture-in-picture". You'll see what I mean if you use the footer link to review.
I'll play with it to see if I can get it back to normal, but you'll probably find a fix before I do.
Thanks.
GOT IT!
Using the same link (you provided) everywhere works, but I had to change the JCE settings to allow JS.
Thank you.
Tom
Thanks.
GOT IT!
Thank you.
