#100055 Text style on an article as mediabox
Latest post by Ryan on Monday, 24 June 2019 14:52 BST
drmenzelit
we have a problem with the text style on an article that is opened on a media box (on a contact form we link the legal notes article as modal window) . The definitions here .wf-mediabox, .wf-mediabox * overwrites the styles of headings and text from the template, there is no differences between a h2 and a p. How can we solve this problem?
Best regards
Viviana
kunze-medien
Hi Ryan, the Problem can be solved by changing jcemediabox.css (quick and dirty fix)
to:
.wf-mediabox, .wf-mediabox .wf-mediabox-close
and add
left: auto;
to
.wf-mediabox-theme-squeeze .wf-mediabox-close {
    right: -1em;
    top: -1em;
    left: auto;
Please post a link to an example popup.
kunze-medien
Please scroll down to the end of Site and klick "Datenschutzerklärung" before Submit button
kunze-medien
By the way, on this popup, there are issues with the width of it. It would be expected 80% of full width, but it doesn't show it.
kunze-medien
Hey Ryan, are there any news yet to solve this problem?
Is there anything we can do?
kunze-medien
We noticed, version 1.2.9 did not have this issue. It starts with version 2 of Mediabox.
The link above doesn't show the issue anymore, because we have installed version 1.2.9 now.
jythra
I have the same issue since the update to the 2 version.
Regards,
Rachel
Please try JCE MediaBox 2.0.11 RC2 - https://www.joomlacontenteditor.net/downloads/mediabox/development
kunze-medien
again on the same page as above installed, but unfortunately no improvement.
See for yourself https://kunze-medien.de/service/kontakt.html#default0_checkbox_inline-lbl and click on Datenschutzerklärung
@kunze-medien - Despite my best efforts I cannot find the cause of the popup issue on your site, except to say that if the popup is set as an iframe type popup, instead of internal content, it opens correctly.
Please try this, by setting the Media Type of the popup (in the Popups tab) to "Not Set" or "External Links / Iframe"
kunze-medien
sorry but we have around 300 web pages and we can not customize them all.
No idea how much has changed in the new version 2.x, but with the JCEMediaBox 1.2.9 everything looks good.
Maybe it's up to the JS to calculate the sizes without a fixed value on the parent, so there will probably be problems with the size calculation of the child.
I am not able to replicate you issue on a local site, so it is very difficult to locate the specific issue causing this problem.
If you can send me a login, I can try a few changes on a 2.0.11 version to see if a fix is possible - https://www.joomlacontenteditor.net/contact/site-login
kunze-medien
I can't give you a login for this site.
so please read my private message.
kunze-medien
Placeholder as File
placeholder.zip
Please try JCE MediaBox 2.0.11 RC3 - https://www.joomlacontenteditor.net/downloads/mediabox/development
kunze-medien
Installed, see for yourself https://kunze-medien.de/service/kontakt.html#default0_checkbox_inline-lbl and click on Datenschutzerklärung.
There is only a height problem left over.
Yes, I have no idea what is causing the issue.
I'm afraid you will either have to use the iframe method to display those pages, as suggested above, or use the older version of Mediabox.
Without being able to test it directly on your site (the test site is not suitable), I am unable to replicate the issue and attempt a fix.
Ok, I may have solved it. Please try RC4 - https://www.joomlacontenteditor.net/downloads/mediabox/development
kunze-medien
Thats it!
I'm so happy. What was the problem?
What is the solution?
After a lot of trial and error, I discovered, for some unknown reason, that the man content box for the popup required an overflow:inherit style to be set on it.
