#99916 Problem when inserting a link into an article using 3.7.13
Latest post by Madshark on Monday, 20 May 2019 04:40 BST
redemptoristsuk
I upgraded to JCE Editor Pro 3.7.13
If I try to insert a link into a document using weblinks I get an error.
I get as far as selecting weblinks, then when I click on the category I want the message error appears (see attached).
I get the same problem on all sites.
I removed the package and installed 3.7.12 and the problem disappears. Reinstall 3.7.13 and the problem reoccurs
Please try JCE Pro 2.7.14 Beta 3 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
redemptoristsuk
Thank you that has fixed the issue
piti45
I had the same problem , 2.7.14 Beta 3 solved it 😃 - great!
Madshark
I had the same error here too. Installed JCE Pro 2.7.14 Beta 5 and all seems good now. 😃
Thanks.
