Hi Rian.
I use mediabox in my components.
I have problem when i change ther link by js.
Mediabox use always the initial link of the html page, and not the link generated by JS.
I use
for change the url, but the new value is ignored.
Regards.
I use
var url = ....
url += ...
document.getElementById('gski-statsclub-link').setAttribute('href', url);
document.getElementById('gski-statsclub-link').click();
Regards.
The popup link and other popup options, is processed and stored when the page loads, not when the link is clicked. Therefore changes that are made to the link or options after this processing are not applied to the popup.
#98845
Arg.
There really is not a solution to send parameters related to the selections of the user to the page called in the popup ?
Can i send a form with post variables instead of a a tag and get variables ?
You can trigger a popup programmatically using the jcepopup.open method, eg:
title : A title for the popup (optional)
group : A group to assign the popup, eg: "nature" (optional)
type : The popup type, eg: "image" (optional)
params : An options object, eg: {"width" : 800} (optional)
jcepopup.open(url, title, group, type, params);
