Hello JCE-Team!
Since the last Update to JCE 2.6.36 (Pro) we have a strange behavior in linking to an article using the existing menu structure.
When choosing the menu point, it loads all existing articles, instead of just the appropriate ones.
Please see:
https://drive.google.com/file/d/1R2Q-qvMtj2bk3gC_O3eoWnwxAbApy83P/view
JCE shows always the same articles although they are, in reality, not connected to those menu points
It always loads the full article list and does not differ if those articles are linked to the highlighted menu point.
As we have a number of articles, it is quite painful to go through the whole list for finding one specific.
We did not encounter this problem before update. I am happy to provide you with any information needed and could setup a test environment.
We would be happy for your thoughts and assistance on the matter...
- Linking to articles shows all articles (not mulitlingual)
- Afink
- Tuesday, 26 February 2019
Pending Moderation
Which version did you upgrade from?
- more than a month ago
Pending Moderation
Hello Ryan,
I think we had version 2.6.33 installed, but I am not sure. I'm installing a backup locally as we speak, so I can confirm in about an hour... yes, the site is quite big and it needs some resources to install the backup.
I'll confirm as soon as possible.
Edit: Yes, it was 2.6.33 before update and I just confirmed with the editors, the above mentioned problem did not occur with the 2.6.33 version.
Pending Moderation
I can see where a change in the relevant code occurred in an update after 2.6.33, but I can't reproduce the issue in any tests.
An option was added in 2.6.34 to show unpublished items in the link tree. Do you have that option enabled in Editor Profiles -> Plugin Parameters -> Link?
Pending Moderation
Hello Ryan,
I can confirm this setting for all profiles. I even put "Show unpublished" to "Yes", saved and reverted it again with no change in behavior.
Besides, I checked some of the articles in the list and they are published.
I'm open to any other suggestion.
Pending Moderation
Pending Moderation
Hello Ryan,
Sorry for the late reply. I had to create a GDPR conform test environment. I sent you the login to the site.
Please bear in mind that any modification should be documented as I have to adjust it on the live site afterwards.
Thanks!
Thanks!
Pending Moderation
The test site is running Joomla 3.6.5. Is there any particular reason you are not using the latest version?
Pending Moderation
as mentioned on the form where I submitted the login informarion, we are at an impar with the subscription component. This vital piece of our site is abandonware and we are planing to migrate to another solution which is quite problematic.
At the moment we have to stick with this Joomla version or we will loose all subscribed users and, subsequently, the income to mantain the site.
Pending Moderation
The problem here is that I can't determine whether this issue is with this old version of Joomla or not, as I am unable to reproduce this in JCE Pro with Joomla 3.9.x
Pending Moderation
I have now tested JCE Pro 2.6.36 Joomla 3.6.5 with the default "Learn Joomla" content, and I am unable to reproduce the issue.
I am however seeing a similar issue on your site when using the Joomla Article button at the bottom of the editor. Can you confirm this?
Pending Moderation
No, as per my investigation (see https://drive.google.com/file/d/16HOS0BKwa3GWQvoW_8P3bwF5Yg37Gero/view ) the Joomla article button, when chossing the right category, works as expected.
I hope you are refering to this function, right?
Pending Moderation
Please try JCE Pro 2.6.38 beta 1 - https://www.joomlacontenteditor.net/downloads/editor/pro/development/item/jce-pro-dev
I have successfully tested this on the site you provided a login for.
Pending Moderation
https://media.tenor.co/images/d9c2ecddc46604d75dd58151ed415ffa/raw
That did the trick and I already implemented it at the live site. I hope it wasn't a problem on our side?
Anyway, thanks so much, Ryan!
Pending Moderation
Joomla versions before 3.6 don't have a query method that JCE 2.6.34+ was using to get the article list under certain conditions. This was causing all articles to be displayed, regardless of category.
I have corrected this, and the fix will be included in the next JCE 2.6.38 release.
Please note that JCE Pro 2.7.0 will require the latest Joomla version.
Pending Moderation
Thanks for clarifying!
I hope we can get the migration done this year as we will need some outside help, which is very hard to find. Until then we will stay with 2.6.x version.
