- JCE Editor PRO not loading
- YaegerDesign
- Friday, 21 September 2018
I'm using JCE Pro 2.6.32 on Joomla! 3.8.12 and the editor will not load at all. I've tried reinstalling, installing old versions, installing the dev version--nothing works. I get an error in the console when editing an article. If I try to use the Save/Close buttons, I get another error. TinyMCE works perfectly.
Attachments (1)
Pending Moderation
In the Editor Global Configuration, please set Compress Javascript and Compress CSS to No.
- more than a month ago
Pending Moderation
Uncompressing Javascript seemed to fix the issue. I'm not sure how much it helps the load time, but is this something that will eventually work?
Pending Moderation
It does work (otherwise it wouldn't be an option) but on some servers capacity or memory limitations might result in an error when compiling and compressing the javascript files, which results in the editor not loading.
Pending Moderation
It was definitely working before. Something happened in the last few minor Joomla! updates.
