  1. hopinn
  2. JCE Editor
  3. Thursday, 31 May 2018
if i upload some pic, the exif data that is uploaded with it, is giving me a headache. I set the radio button for Remove Exif to yes, but still the image still contains the exif data from before the upload. How come? How can i solve this? Is this due to an Apple camera device (Iphone SE)?
Thank you.
Attachments (2)
The feature is dependent on a few common PHP extensions, which your server might not have installed.
  1. more than a month ago
  2. JCE Editor
  3. # 1
I have tested 2 images on your site - a stock photo and an iPhone SE photo - and both had their exif data removed on upload. This was checked using exiftool on macOS and the site you used - http://www.verexif.com/en/ver.php
What pixel size (width x height) is the file you are having an issue with?
Is the EXIF data removed on smaller files?
  2. JCE Editor
  3. # 2
The files i tried to upload are visible on https://tastycreations.be/v1, these pics should be shown in portrait.
i stored them for download in this zip https://tastycreations.be/images/groensels/2018/v1/withoutexif/exifpics.zip.
The pics are taken with ios (iphone) but i want to convert them/ upload them on a windows pc.
Thank you.
As you see i didn't work yet to get rid of exif data.
can you help me? Thank you.
References
  1. https://tastycreations.be/v1
  2. https://tastycreations.be/images/groensels/2018/v1/withoutexif/exifpics.zip
  2. JCE Editor
  3. # 3
The basic Image Manager does not remove EXIF data on upload.
I have added the Image Manager Extended to your "Default" profile. This will remove the EXIF data from images on upload (tested with 20180510.jpg)
  2. JCE Editor
  3. # 4
i downloaded the Image Manager Extended, but where can i install it (on an other site)? Where can i find the JCE Installer, which is already an installed plugin.
Thank you.
  2. JCE Editor
  3. # 5
Image Manager Extended is already included in JCE Pro.
You can add the Pro buttons you require in Editor Profiles -> Features & Layout - https://www.joomlacontenteditor.net/support/faq/plugins/buttons-missing-from-the-editor-toolbar-after-update
  2. JCE Editor
  3. # 6
Thank you, this works fine, problem solved!
  2. JCE Editor
  3. # 7
