Hello
i found out my Popup are not working anymore
http://www.kocher.reisen/index.php/home2/myartikel/189-messer-victorinox-ranger
the ICE Mediabox is active and the Theme is light - but also to change the Theme is no difference
any idea wher to dig?
have a nice day
vinc
Pending Moderation
In Extensions -> Plugins, please make sure System - JCE MediaBox is enabled.
Pending Moderation
Have you set the Exclude Components, Assign to Menu or Exclude from Menu options in the MediaBox parameters?
Pending Moderation
Pending Moderation
I have exactely the same problem. Yesterday I updated the JCE and now the popup is no longer working.
Did you find the problem?
Regards Heike
Regards Heike
Pending Moderation
Updating JCE should not affect JCE MediaBox or existing JCE Mediabox popups. Please post a link to an example.
Pending Moderation
This is the link
http://www.baiblues.de/index.php/schlagzeilen/596-19-03-2017-max-bairan-zu-besuch
Best regards Heike
Best regards Heike
Pending Moderation
Please upgrade JCE MediaBox to the latest version - https://www.joomlacontenteditor.net/downloads/mediabox/category/joomla-3
Pending Moderation
I have the same problem...The popup doesn't work...The image open in a new tab.
Could you please help me?
Joana
Joana
Pending Moderation
topinformatica Please post a link to an example popup.
Pending Moderation
https://www.topinformatica.pt/novidades.php?categoria=all&programa=all&versao=10
See Capturar.PNG to click on correct image.
Attachments (1)
Pending Moderation
topinformatica JCE MediaBox does not appear to be installed or enabled on your site. I don't see the MediaBox scripts being loaded in the site front-end.
Pending Moderation
Yes, JCE MediaBox is required to show the popups - https://www.joomlacontenteditor.net/downloads/mediabox/development
Pending Moderation
Sorry, but I don't understand. I need to copy de javascript and css to my webpage. Is that?
Pending Moderation
No, you need to download and install the JCE MediaBox plugin - https://www.joomlacontenteditor.net/downloads/mediabox/development
After installation, it must be enabled, see - https://www.joomlacontenteditor.net/support/installation/mediabox
Pending Moderation
Have you made any changes to the MediaBox parameters, such as assigning it to a Component or Menu?
Pending Moderation
Is this a Joomla site? None of the links - eg: https://www.topinformatica.pt/novidades.php?categoria=all&programa=all&versao=10 - look like Joomla urls.
Pending Moderation
No, backoffice is joomla...The site is php and read information the joomla only
Pending Moderation
JCE MediaBox can only run in a front-end Joomla site.
Pending Moderation
its the same on my site http://www.praxisklinik-brahmsallee.de - the pop-up dosn´t work
i have install the lastet JCE Pro 2.8.19 Beta 6 and the JCE MediaBox 2.1.2 RC 3, but in the backend i have no button.
The pictures on the site can not open in a popup, only in a nwe site
Pending Moderation
This is the standard image manager not the image manger extended.
You have to add the image manger extended button to your editor layout
https://www.joomlacontenteditor.net/support/faq/editor/pro-buttons-missing-after-upgrade
