- Problem creating links to list articles tagged
Hello
When I create a link in the JCE Editor to list all the articles having a specific tag (say "marketing") using the search tool to find the tag (e.g. search / tag/ marketing)
The following link is produced in the editor
index.php?option=com_tags&view=tags&id=94&Itemid=3210
It gets rewritten somewhere and displays a page
https://12faces.business/component/tags/?id=94&Itemid=3210
Which should be showing the articles tagged with tag ID "94" but is actually showing all the tags themselves.
If I create a dummy menu entry, I get the URL format
index.php?option=com_tags&view=tag&id[0]=94&types[0]=1
which then rewrites to (for tag ID=94)
https://12faces.business/component/tags/tag/94?types%5B0%5D=1
Which works as desired.
Are you able to help please.
Scott
Scott
If you use the tree list in the Link dialog to get the Tag url, is the resulting url different?
#108337
My apologies.
I did actually use the "tree list". I did not separate it from the "Search" in my mind.
The "search" for the Joomla Tag by name "sid10" or Joomla Tag ID "94" does not return anything.
Scott
Scott
Please try JCE Pro 2.9.11 Beta 3 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
#108351
That appears to work correctly using the "tree" drill down approach.
I am not sure if you expected it to work in the "search" box but it DOES NOT find a tag by its name if you were expecting it to work.
I am happy to use the tree approach
Many thanks for your help.
Best wishes
Scott
Best wishes
Scott
The Search function uses the same API as your site front-end search, and returns the same result. It works as expected in my tests.
What happens when you search the front-end of your site for that tag?
#108364
When I search front end, it does not return a link for the tag's name but will return a link for the listing display of all articles with that tag's Joomla ID.
That is the only tag front end search returns and is the only one I have created with JCE.
That link is created by me via JCE so the Joomla search is only displaying created links. I would therefore not expect the JCE search box to return a link not yet created if my understanding is correct.
I am conscious that I am using a lot of your time so am happy to say the issue is solved from my POV.
Scott
Scott
That is what it is supposed to do, eg:
https://12faces.business/search?q=marketing&Search=&t%5B%5D=188
The JCE Search should return something similar.
