#107278 "Read More" disappear after editing in Front-End
Latest post by Vlad Ghitulescu on Tuesday, 30 March 2021 14:41 BST
Vlad Ghitulescu
Hey!
After editing a text of an article in Front-End the "Read More" disappear.
Even after putting "Read More" back it disappears again!
The Code Editor shows the whole text put in a single paragraph-tag after editing anything at all and <hr id="system-readmore" /> disappear every single time.
This happens with different articles as well.
Any idea?
Thanks!
Regards,
Vlad
Vlad Ghitulescu
Hello again! It's even worse: adding another list item to this text (as in Code Editor) ---
<p>Das sind die PDF-Dateien:</p>
<ul>
	<li><a href="https://www.joomlacontenteditor.net/images/pdf/Rechnung_2020-12-21_MUSIC_STORE_professional.pdf" class="wf_file">Rechnung_2020-12-21_MUSIC_STORE_professional.pdf</a></li>
	<li><a href="https://www.joomlacontenteditor.net/images/pdf/Rechnung_2020-12-23_Heimeshoff_Riese_-_UmsatzSteuer_2019.pdf" class="wf_file">Rechnung_2020-12-23_Heimeshoff_Riese_-_UmsatzSteuer_2019.pdf</a></li>
	<li><a href="https://www.joomlacontenteditor.net/images/pdf/Rechnung_2020-12-27_LinkedIn_Learning.pdf" class="wf_file">Rechnung_2020-12-27_LinkedIn_Learning.pdf</a></li>
</ul>
<p>Viel Spaß damit!</p>
--- leads to this: ---
<p>Das sind die PDF-Dateien: Rechnung_2020-12-21_MUSIC_STORE_professional.pdf Rechnung_2020-12-23_Heimeshoff_Riese_-_UmsatzSteuer_2019.pdf Rechnung_2020-12-27_LinkedIn_Learning.pdf Rechnung_2021-01-19_Domkapitel_-_Mina_Ghitulescu.pdf Viel Spaß damit!</p>
--- that is: the content of the Editor-window has replaced the content of the Code Editor. Regards, Vlad
Does this only happen when you save, or when you switch to the Code tab?
Vlad Ghitulescu
Hey, Ryan!
It's only after saving. I've find out that the inserted images disappear as well.
I'm pretty sure that I'm the culprit myself but I couldn't figure it out yet. :-(
Regards,
Vlad
This is most likely caused by the Joomla Text Filter, in the Joomla Global Configuration. For Super Users, set the Filter Type to No Filtering.
Vlad Ghitulescu
That was it, Ryan! Thank you very much!!!
