- Problem with
Problem with
I having the problem that I have been using JCE pro well for years but all of a sudden it shows the error below in the backend (i had switched on the debug)
On the frontend, it shows some 500 errors that both have to do with the language file.
I thought it had to do with the standard backend language (which I had changed recently to German) but no thats not it either.
Here is the weird thing. It works on my other sites perfectly normal.
Joomla\CMS\Filesystem\Path::check() - Snooping out of bounds @ ---path--/administrator/components/com_jce/views
---path--/libraries/src/Filesystem/Path.php:188
Call stack
# Function Location
1 () ---path--/libraries/src/Filesystem/Path.php:188
2 Joomla\CMS\Filesystem\Path::check() ---path--/libraries/src/MVC/Controller/BaseController.php:452
3 Joomla\CMS\MVC\Controller\BaseController->addPath() ---path--/libraries/src/MVC/Controller/BaseController.php:1041
4 Joomla\CMS\MVC\Controller\BaseController->setPath() ---path--/libraries/src/MVC/Controller/BaseController.php:417
5 Joomla\CMS\MVC\Controller\BaseController->__construct() ---path--/administrator/components/com_jce/controller.php:40
6 JceController->__construct() ---path--/libraries/src/MVC/Controller/BaseController.php:302
7 Joomla\CMS\MVC\Controller\BaseController::getInstance() ---path--/administrator/components/com_jce/jce.php:33
8 require_once() ---path--/libraries/src/Component/ComponentHelper.php:402
9 Joomla\CMS\Component\ComponentHelper::executeComponent() ---path--/libraries/src/Component/ComponentHelper.php:377
10 Joomla\CMS\Component\ComponentHelper::renderComponent() ---path--/libraries/src/Application/AdministratorApplication.php:101
11 Joomla\CMS\Application\AdministratorApplication->dispatch() ---path--/libraries/src/Application/AdministratorApplication.php:159
12 Joomla\CMS\Application\AdministratorApplication->doExecute() ---path--/libraries/src/Application/CMSApplication.php:203
13 Joomla\CMS\Application\CMSApplication->execute() ---path--/administrator/index.php:51
Call stack
# Function Location
