#106808 Default margins for images in em
Posted in ‘Suggestions & Feature Requests’
Latest post by Ryan on Friday, 12 February 2021 15:40 GMT
ClaudioRomeo
I use profiles.
In the Plugin Parameters → Image Manager Extended → Default Values area I can only set the margins to 10px max.
How can I set the default value to 20px?
Moreover, how can I set the default value to 1em?
I would suggest using css styles for this rather than applying inline margin styles, especially if you want to use em values. So for example, you could add thie following to your template stylesheet, and then select it to apply to the image from the Stylres list:
.img_margin {
    margin: 1em;
