Bonjour, il y a un problème de mise en forme des caractères, concernant le B pour mettre le texte en gras, quand on clic sur le B de Bold ça transforme le texte en majuscule et en gras, alors que ça devrait conservé la mise en forme (en minuscule) et juste le mettre en gras, quand pensez-vous pouvoir régler ce problème ? Ce problème existait déjà dans la précédente version. J'ai acheté la version pro, et ça serait bien que ça fonctionne correctement, j'attends de vos nouvelles rapidement.
#106789 Character formatting problem in bold - URGENT
Latest post by christianferreira on Friday, 12 February 2021 16:05 GMT
Thursday, 11 February 2021 10:42 GMT
Thursday, 11 February 2021 11:46 GMT
strong {
font-weight: bold;
text-transform: uppercase;
You will need to change this in your template stylesheet, or add an alternative rule to a custom css file your template has, eg:
strong {
text-transform: inherit;
Which template are you using? Ryan Demmer
Thursday, 11 February 2021 14:28 GMT
Thursday, 11 February 2021 14:36 GMT
Thursday, 11 February 2021 14:52 GMT
Friday, 12 February 2021 14:15 GMT
Here is rsjoomla's response:
Hello Christian,
The same is happening on your standard Joomla! articles:
http://www.leclubdespatissiers.com/administrator/index.php?option=com_content
Edit an article, highlight some text and click the B button. You'll notice the text becoming bold and uppercase which isn't related to the template whatsoever.
Please contact your editors developers once again as we can only provide customer support which is directly related to our products.
Regards!
Friday, 12 February 2021 14:50 GMT
Edit an article, highlight some text and click the B button. You'll notice the text becoming bold and uppercase which isn't related to the template whatsoever.This is inaccurate. The editor formats the selected text with a <strong> tag. The template stylesheet includes the text-transform:uppercase style on the <strong> tag in the template stylesheet.
strong{text-transform: uppercase}
It's in the stylesheet for the rscora demo!!! - https://templates.rsjoomla.com/#rscora Ryan Demmer
meanwhile rsjoomla noticed the problem with the template. Here is the answer :
Hello Christian,
After a further investigation your are indeed correct. This came from the template CSS since your editor loads its CSS within the iframe (where your editor is loaded). The template provides a custom.css file specially for such cases to override certain definitions or to add new one, though I've tried this on your website and your editor doesn't load the template's custom.css file as well.
Nevertheless, we've however further adjusted the template to no longer have this uppercase definition applied on bolded text by default. I've updated the template for you and the issue has been resolved.
Please wait
Your post is being submitted…
