- Create content links to J2Store products
I am using J2Store and JCE on a few websites for my clients.
J2Store products are Joomla articles.
If I create in a blog article with the JCE link to a J2Store product, the html link is not using the J2Store url parameters.
The link created is:
This will link to the product in com_content views. I need a link to the J2Store views like:
The "&Itemid=147" could be omitted, but the com_j2store is important.
How could I solve this? Right now the client is copying absolute URLs which is not a good way.
Actually an option for j2store products (see 3rd attachment) would be great.
Sigrid
<a href="/?view=article&id=15:die-helle-freude-bio-akazienhonig&catid=15:bio-honig">Honig</a>
<a href="/component/j2store/?view=products&task=view&id=25&Itemid=147">Honig</a>
Sigrid
Ah, while investigating I found the problem myself.
However, it is kind of tricky.
in your plugins you need to enable the search plugin for J2Store.
And in your JCE Profile, in the plugin params for links at the very bottom, you have to add the search plugin (see attachment)
Then in the link search within your editor view, articles and products will be found. however, the look like the same.
you have to find through clicking, which one produces the correct j2store link.
I just wanted to post it, so that if someone else has the same problem, they will find it here
Thanks anyways!
Thanks anyways!
I have made a change to the search display so that the results are displayed by component. You can test this in JCE Pro 2.9.2 RC - https://www.joomlacontenteditor.net/downloads/editor/pro/development
