#106221 Problem with saving Plugin Parameters in Joomla 4 (other parameters ok)
Latest post by jparker3119 on Thursday, 31 December 2020 03:11 GMT
jparker3119
JCE 2.9.1
Please find attached system information, if you should require it. ( Well, I thought I would but neither extension .txt nor .php was a "supported format" so was unable to.....)
I have installed JCE into Joomla 4's latest version.
Saving new settings from JCE > Editor Profiles > (default as installed) > Editor Parameters > various setting are saved without any problems.
However,
Saving new settings from JCE > Editor Profiles > (default as installed) > Plugin Parameters > no settings are saved.
I understand that this is "Alpha" but thought that this might be of interest to you.
I'm not seeing any issue in my tests. Please try JCE Pro 2.9.2 RC - https://www.joomlacontenteditor.net/downloads/editor/pro/development
jparker3119
It's working fine with 2.9.2 RC. I wonder that it might not have been my over-worked eyes making me see things!!!
Thanks for you quick reply.
