- Searching for article in link tool doesn't always show correct article
Hi there! :-)
When I shall insert a link from one article to another article I normally use the search function, in the link tool, to find the article I want to link to. Normally this goes fine, but sometimes I can't search for the wanted article, it doesn't show up?
Probably best explained in the attached video link.
Please try JCE Pro 2.9.2 RC - https://www.joomlacontenteditor.net/downloads/editor/pro/development
