"All help and description tooltips in the JCE Admin have been converted to inline help blocks."
I absolutely loath this, I now find it very hard to find what I need in the profile settings.
Is there a way to turn it off?
I do understand that you want it on by default to help reduce your support time.
Maybe a button that turns it off just until you login again???
- Turn off "help and description tooltips converted to inline help blocks"
- saraheagle
- Friday, 20 November 2020
Pending Moderation
This has been added to JCE Pro 2.9.2 Beta 12 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
In the JCE Control Panel, click the Options button in the top right, and set Inline Admin Help to No.
- more than a month ago
- # Permalink
Pending Moderation
Only by adding some css to the admin template stylesheet, eg:
.ui-jce .control-group .description {
display: none;
Not at all. Joomla 4 includes all form field descriptions inline, so this change just anticipates that. Also, I'm pretty sure most users didn't even realise that a tooltip description was available for each field, so this does help some to understand the parameters better.
Pending Moderation
I am adding an option in the next update to turn off inline help, reverting to the tooltip based help.
Pending Moderation
Oh super! Thank you so much
