#105862 Autoplay video and mouse hover sound
Latest post by ant on Wednesday, 11 November 2020 07:36 GMT
ant
Hi Ryan, is it possibile for an autoplay mp4 file to get sound only with mouse hover? I mean that on loading page the file plays with no sound (volume 0), when mouse is hover the video, the volume goes to 70%.
Regards
You would need some additional javascript to do this. You could try the following jQuery script (not tested!), where "video_id" is the id attribute value of the video:
jQuery(document).ready(function($) {
    $('#video_id').on('mouseover', function() {
        this.volume = 0.75;
    }).on('mouseout', function() {
        this.volume = 0;
    }).get(0).volume = 0;
ant
Hi
thanks a lot for your suggestion.
Please, let me know if it is correct how I assigned the attribute to the mp4 file into attached image.
I'm trying to add the script using Regularlabs Sourcerer plugin but I get only text after insert. have I to change settings in JCE?
Reagards
No, in the Advanced tab, set the ID attribute to "video_volume" or anything else, then use that value for the "video_id" part of the script. For example, if you set the ID value in the Advanced tab to "video_volume", then the script would be:
    $('#video_volume').on('mouseover', function() {
        this.volume = 0.7;
        this.volume = 0;
It's not ideal, but you can just add the script to your content before or after the video. If Allow Javascript is enabled in Editor Profiles -> Editor Parameters -> Advanced, then paste in the following:
<script type="text/javascript">
        this.volume = 0.7;
        this.volume = 0;
</script>
ant
Great! It works fine. Thanks again.
Sorry if I take this opportunity, is it possible to gradually increase the volume and gradually decrease the volume at the entry and exit of the mouse?
Try this (from https://stackoverflow.com/questions/7451508/html5-audio-playback-with-fade-in-and-fade-out) :
        $(this).animate({volume: 0.7}, 1000);
        $(this).animate({volume: 0}, 1000);
</script>
The 1000 value is equivalent to 1 second, which is the fade in/out time, so adjust as required. FYI - without the fade in/out, you could probably do this without the extra javascript, but just with event attributes, eg:
<video src="https://www.joomlacontenteditor.net/video.mp4" onmouseover="this.volume=0.7;" onmouseout="this.volume=0;" onloadedmetadata="this.volume=0;"></video>
ant
Thanks a lot.
