#105817 JCE 2.9 code block problems
Latest post by apartners on Thursday, 12 November 2020 17:26 GMT
Giuse
Hi, I write the very simple attached text in JCE 2.9.2 beta 4.
I save it and JCE does not detect code block (1st problem). Then I cut and paste the 3 php lines and now code block is activated.
Then duplicate the 3rd line and save: the added line gets stripped and the second line gets duplicated.
Could you pls see and eventually fix?
thanks
Giuse
Giuse
I am not able to attach the file, and also writing it here does not work (after hitting "Reply" nothing happens...) maybe because there is some php code?
please see link
Please try JCE Pro 2.9.2 Beta 5 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
Giuse
fixed, thanks
apartners
I have a similar problem. When I install and use either 2.9.1 or 2.9.2 Beta any <iFrame>...</iFrame> I add to an article gets completely deleted when I tiggle between HTML view and normal Editor View. When I fallback to version 2.8.18 everything works just fine - nothing gets stripped.
What have you set for Allow IFrames in Editor Profiles -> Plugin Parameters -> Media Support?
apartners
All "Allow" settings are set to "Yes" - - Note that If I don't toggle from HTML source mode I can successfully save the article with the <iFrame> content intact. It only strips the iFrame when I toggle to Editor mode
I just installed 2.9.2 Beta 9 and it did not fix this issue.
Please post a screenshot of the code you are attempting to add to the editor.
apartners
Screen Capture of <iFrame> code that gets stripped is attached.
@apartners - Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
apartners
Done...
On your site, the Allow IFrames option in Editor Profiles -> Plugin Parameters -> Media Support was set to No, which is why the iframe was being removed.
https://cdn.joomlacontenteditor.net/tmp/105817-jce-2-9-code-block-problems.jpg
I have set this to Yes on your site to resolve the issue.
apartners
Thank you! I should have seen that setting and figured it out myself... 🙁
