  1. Adrianv
  2. JCE Editor
  3. Saturday, 17 October 2020
Hi, Can you please help. I have purchased JCE Pro. I am having great difficulty installing it in Joomla.
I have followed the instructions you published on your website. You say, after downloading JCE use the manage-install process to install, however, in the package folder there are eight packages, which one do I pick?
Also (hopefully) when I install it, do I need to activate the pro version. Please give me a simple and comprehensive reply as it's very frustrating.
Yours Sincerely
Adrain.
Thanks for your reply. Just for the record, I am installing on a Mac. I have sorted out the issue.
When you download the file you need to compress the folder and then use the install process to upload JCE to Joomla.
  1. more than a month ago
  2. JCE Editor
  3. # Permalink
You should not unzip the package after you have downloaded it. You should only select and upload the single pkg_jce_pro_2818.zip file.
After installation, assigne the Pro buttons you require to the editor toolbar - https://www.joomlacontenteditor.net/support/faq/editor/pro-buttons-missing-after-upgrade
  2. JCE Editor
  3. # 1
By default, Safari will automatically uncompress a downloaded zip file, which can, and probably should, be disabled. In Safari, go to Preferences, then in the General tab, uncheck Open "safe" files after downloading.
  2. JCE Editor
  3. # 2
