  1. hundenarr
  2. JCE Editor
  3. Wednesday, 07 October 2020
Dear JCE Editor Team,
I am trying to add a script code into an article. In JCE code preview and it is working, but when I am switching back to "Editor" tab and back to JCE code preview, some parts of the code is removed.
JCE Editor modifications made in an attempt to save code:
Joomla Filtering - Set to No Filtering for the user group
'Editor Parameters' - 'Cleanup and Output' Setting - I set the Validate HTML setting to - No
'Advanced' Settings - 'Allow Javascript', 'Allow CSS' and 'Allow PHP' to - Yes
'Plugin Parameters' - 'media support settings' - 'Allow IFrames' to Yes
Even if I only open an article in editor tab view without switching to code preview, parts of the script are removed after saving text changes. Any hint, what can be doneto prevent this?
I add screenshots of the sourcecode before switching to the Editor tab, and what it looks like after switching back to the Code tab.
Attachments (2)
The <daa-wgt> tag is not valid HTML and is an empty tag, which is why it is removed.
Please try JCE Pro 2.8.19 Beta 6 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
This includes a new system of Code Blocks that allow script tags and custom XML (like your <daa-wgt> tags) to be edited directly in the editor.
You will need to enable Allow Javascript and Allow Custom XML in Editor Profiles -> Editor Parameters -> Advanced.
  1. more than a month ago
  2. JCE Editor
  3. # 1
I installed JCE Pro 2.8.19 Beta 8 and tested it.
It worked, when I added the script in code preview, then switch back to editor tab view and saved the changes then.
Strangely it worked not, when I added the script and saved changes directly in code preview, In this case parts of the script get still removed after saving text changes.
  2. JCE Editor
  3. # 2
  2. JCE Editor
  3. # 3
