  1. nphic
  2. MediaBox
  3. Wednesday, 23 September 2020
Folks,
I'm using JCE MediaBox on my website to display biographies. When I first enter the webpage, a "random" jace mediabox popus on entry. I go into the POPUP tab and select auto popup to "Not Set". When I save it, it goes to "single". How do I resolve this issue?
Joe
I'm not able to reproduce this on the demo site - https://demo.joomlacontenteditor.net
Are you creating the popup with the Link dialog or Image Manager Extended?
Which version of the editor do you have installed?
  1. more than a month ago
  2. MediaBox
  3. # 1
Ryan,
I am doing it from the link dialog. I'm using JCE Editor Pro v2.8.17. I was able to workaround it by deleting the popup code from the html. It be great if you see and are able to resolve this issue, but no rush. At least I have a workaround.
Joe
  2. MediaBox
  3. # 2
