I use RSForm.
In the Textarea field with WYSIWYG editor, JCE does not work. JCE does not even allow text entry
can you help me?
this is the test link: https://www.nelbelsalento.it/it/prova-jce
- JCE does not work with RSForm
- Ferriero
- Friday, 14 August 2020
Pending Moderation
@Ferriero - Check that the default profile you are using is assigned to All Components in Editor Profiles -> Setup, or that you use a specific profile for RS Form, such as a modified version of the example Front-end profile, as suggested by @jeffhoneyager above.
- more than a month ago
- # Permalink
Pending Moderation
Be sure you publish the "Front End" profile.
Here's my form with JCE
Attachments (1)
Pending Moderation
Resolved!
thank you so much!
thank you so much!
Pending Moderation
You are welcome.
Keep on JCE-ing!
Keep on JCE-ing!
