  1. austin7_2017
  2. JCE Editor
  3. Tuesday, 04 August 2020
Have JCE Pro & have been using it successfully on many installations for a number of years.
I have an issue with one installation:
When clicked, the Link Creation Dialogue pops open but it is totally blank - just a white dialogue, ie no options to create a link.
The site is running Joomla 3.9.20 Stable, the php is 7.4.7 & the JCE Pro version is 2.8.15.
Any ideas how this can be fixed?
Remove the Search - Web Links option, as you may not have this component installed (it is not included with the core Joomla install)
  1. more than a month ago
  2. JCE Editor
  3. # Permalink
Please go to Editor Profiles, and click on your main profile to edit it, eg: "Default"
Then click on the Plugin Parameters tab, then on the Link tab on the left, and scroll down to the Search options.
In the Link Search plugins section, what options are visible? eg: Search - Categories.
  2. JCE Editor
  3. # 1
Ryan,
Thanks for the response.
I have screencapped that page section & attached it as a jpg.
From all I see, this function should work - it does on other installations, which is why I am appealing for some help/guidance.
Bill
Attachments (1)
  2. JCE Editor
  3. # 2
Thank you Ryan!
That's fixed it!
Bill
  2. JCE Editor
  3. # 3
