#104940 Java is not working - after upgrade to JCE Pro 2.8.15
Latest post by vindheim on Friday, 31 July 2020 09:29 BST
vindheim
"Set the Allow Event Attributes option to Yes. The Allow Event Attributes option will not be visible but will automatically be enabled if the Allow Javascript option is enabled."
This is not working with upgrade to JCE Pro 2.8.15.
You need to manually set Allow Event Attributes option to Yes - first.
If not, your javascript is not working.
vindheim
The problem is when you switch between WYSIWYG and Code mode - java script get lost - even Google Adsense code.
I have also tried beta 16 - same problem.
vindheim
JCE Pro 2.8.12 is the latest working version.
This is working in my tests.
Please post an example of the code, or a screenshot of the code, you are trying to insert.
Please try JCE Pro 2.8.16 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development/jce-pro-2-8-16-dev
vindheim
2.8.15 My code - in code view - save and it works:
Switch to WYSIWYG - save - don't work
THE SAME PROBLEM WITH 2.8.16beta - 4
WORKING WITH 2.8.16beta - 5 - THANKS !
