I've been a JCE user for a long time (since Joomla! 1.0) and I keep using it in all my projects.
I'm also a Fabrik user and, since the JCE 2.8 release, I have an issue working them together in the back-end (only): opening a Fabrik list or form for editing creates a serie of JS errors (in editor_plugin.js mainly) that makes impossible to edit the Fabrik item.
Oddly enough, it does not happen ALL the time, but quite often, and ONLY with lists and forms (groups and elements are safe - but elements don't integrate an editor).
JCE 2.7 (up to 2.7.20) works fine. It's really started with any version of 2.8.
I'm not sure whether you can do something about this, but I set up a test site for you to test if you can. Let me know how I can give you Super User access and if you need something else (FTP?).
Kind regards,
Jean-François
Kind regards,
Jean-François
