#103629 [JCE2.8.9] URL conversion to "relative", strip first slash breaking URLs
Latest post by Ryan on Wednesday, 25 March 2020 19:16 GMT
56kagency
With URL "relative" conversion, JCE strips the first slash of the url.
This cause that an url works only in "home page", but if i'm in an other page like "www.mysite.com/blog", the relative url is appended after "blog", breaking the link.
Thanks.
In Extensions -> Plugins, is the Joomla System - SEF plugin enabled?
56kagency
Yes yes, obviously it's active as we are talking about an online site with a strong SEO optimization.
For now I have solved by writing the relative url by hand including the initial slash 😉
In this case JCE leaves the link as it is.
This should not be necessary as this is automatically done by the Joomla System - SEF plugin when the page is rendered.
Please ensure that it is enabled. It must be enabled regardless of the SEF solution you are using.
