Can you tell me if there is any difference between JCE S3 plugin for Amazon and Joomlart S3 plugin ?
Is it possible with JCE S3 to move our entire images, documents and medias folders to S3 in order to only keep the website files on our server ? I mean it's ok for new users to upload and use S3 for new posts, but what about old ones if we do this ? Do you have a mechanism in your plugin to check S3 if the file is not found on the website ?
Also what about other extensions using the images folder for instance (such as CB or hotspots) ? will JCE S3 interact with these to retrieve the S3 correct path ?
