#103300 Tables and images
Latest post by [email protected] on Wednesday, 04 March 2020 22:14 GMT
[email protected]
Hi I am using tables to insert pop up images which work fine but I would like the table to be invisible and only show the images whent they visit the website
what do other people use to insert images
Dave
I'm not sure what you mean here. Can you explain further?
[email protected]
When editing images on web pages using the JCE editor I use tables to put the images into so they are all in order the table are visible in the editor so one can see what you are editing with an option to make the table properties invisible on the actual webpage
Dave
The table is made visible in the editor using guidelines, which are only visible in the editor. When the article is viewed in the front-end, these guidelines do not display.
Are you wanting the tables to be visible in the front-end?
[email protected]
Ryan, I have done a few adjustments myself and everything seems to be working with the JCE editor
Hopefully
Dave
