#102690 Search/Finder: Message not correct
HGH
In the editors finder there is a small bug in the displayed message.
Example:
1. Open finder with cntl-F
You will see a popup like this:
https://dl.dropboxusercontent.com/s/3hqfzcenegob0ls/2020-01-19_15h40_59.png?dl=0
2. Fill in the search term and press "Find".
https://dl.dropboxusercontent.com/s/6vrq7a8la0a5xel/2020-01-19_15h41_35.png?dl=0
3. You see an occurrence of the search term at the highlighted position.
When you then press "Find" again, this message occurs - see underlined text:
https://dl.dropboxusercontent.com/s/1plqyoz9guxvlr1/2020-01-19_15h42_31.png?dl=0
This implies, that the search term was not found, but that is wrong - see 2.
The correct message should be something like this:
Searched to end of document - no more occurrences of the search string found!.
The act. displayed message should only be displayed, when the search term isn't found in the document.
