- JCE Plugins / Addons
- Problem with captions and margins since recent update
Captions is having problems... When you set margins in the article, and then add a caption, the margins are reset to "initial" and the margin is no longer displaying correctly.
If you add the margin back.. the bounding box of the caption now sets the margin - with the caption going to the edge of the margin and the picture being (pushed) by the margin distance.
Is anyone else experiencing this (it is new since last release) and does anyone have any solution or work flow or work around??
Please try JCE Pro 2.8.3 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
No that is not fixed by that update.
Adding a caption distorts the image perspective by replacing the values inserted in the Margin fields with the text 'INITIAL'.
Can't use captions because of that when it was the maim reason I bought the product. I have attached before and after images.
Please advise.
EDIT: While looking at this. After inserting the caption, if the caption text is selected in the editor and the alignment is changed, it affects the nearby text in the article. Only way to change it is the delete it and change the alignment at the time if inserting the caption text. Needs fixing.
Please advise.
To replicate the above. The article has to be refreshed in the website. Sometimes it displays correctly just after inserting the caption in both the editor and the website.
But clicking to Home on the website then back to the article will show the behavior above.
I have removed the caption so there is no error to see now. I have provided screen grabs of what happens.
The site is http://www.qrya.com.au This is the article fixed https://qrya.com.au/index.php/home/latest-news/515-bridge-for-sale-2
The screenshots are not sufficient to troubleshoot the issue, as some styles or scripts on your site may contribute to the problem. I need to briefly be able to see the caption applied to the image find the cause of the problem.
It looks like the image in question on this page - https://qrya.com.au/index.php/home/latest-news/515-bridge-for-sale-2 - is being "lazy loaded" by a script on the site, which could be the cause of the issue.
If you able to disable this (it may be part of your template or an extension you have installed), then we can determine if this is the cause of the display issue. Modern browsers now have lazy loading built in, which you can set on images you insert by setting the Loading option in the Advanced tab of the Image Manager to lazy.
Using browser Developer Tools to edit the displayed HTML I was able to create the caption on your site (see below) and I assume that it is displaying correctly, so there is no other css that is affecting the layout.
This leads me to believe that the lazy loading script I mentioned in my previous post may be the cause of the layout problem.
No caption displaying.
Yes there is. "Corrector weights" is the caption.
So how exactly do I address the lazy loading?
It would seem that you have an extension installed on your site, or a setting in your template, that is implementing the lazy loading on all images on the page. You need to fine this extension or setting, and disable it.
See this post at Rockettheme which may be relevant - https://rockettheme.com/forum/general-discussion/228287-how-where-can-i-turn-off-smartload-on-rochettheme-template#1127822
