FYI, since updating to the 2.8.0 pro the "Class" property on the "Edit Link" dialog no longer has any effect, The class="classname" tag is not inserted. I have to switch to code view and insert it manually.
- Edit Link Class Property Issue
- GuiGuy
- Saturday, 30 November 2019
Pending Moderation
Are you typing in the class name or selecting one from the Classes list?
- more than a month ago
Pending Moderation
I have tried both approaches:
Since updating to 2.8.0 the drop down list in the dialog no longer shows available classes.
If I type the class name into the EDIT LINK dialog's Class Property field it is ignored and never added to the code on OK.
As I wrote, I have to add the code manually in code view. No big deal, but using the dialog would be simpler.
Pending Moderation
I'm also seeing thhis Issue since upgrading to 2.8.0.
Pending Moderation
Please try JCE Pro 2.8.1 RC8 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
Pending Moderation
That seems to have made a mess of the dialog interface. The positioning of the tabs and URL field overlap. I cannot activate the Advanced Tab. See attached.
This is on Firefox. Haven't tried other browsers.
Attachments (1)
Pending Moderation
@GuiGuy - That looks like a javascript error. Please clear your browser cache.
Pending Moderation
Hi
I had already done that. No luck. The problem continues.
NB: Getting the same problem in Chrome and Opera.
Pending Moderation
FYI, I put 2.8.0 back and the dialog presents correctly.
Looks like the distortion is down to RC8
Pending Moderation
I am not able to repduce your issue with RC8 in any browser. Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
Pending Moderation
@GuiGuy - This appears to be fixed on your site now with an install of JCE Pro 2.8.1 RC10 - https://www.joomlacontenteditor.net/downloads/editor/pro/development/jce-pro-2-8-1-dev
Pending Moderation
That seems to be working now.
Many thanks.
Many thanks.
